The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Logs for third-party software
You can use the third-party software logs to troubleshoot issues.
| Category |
File name |
Notes |
Found on |
/var/local/log/dsierror.log
Error information for TSM Client APIs.
/var/local/log/mysql.err
/var/local/log/mysql-slow.log
Log files generated by MySQL.
mysql.err captures database errors and events such as startups and shutdowns.
mysql-slow.log (the slow query log) captures the SQL statements that took more than 10 seconds to execute.
/var/local/log/messages
This directory contains log files for the operating system. The errors contained in these logs are also displayed in the Grid Manager. Select SUPPORT > Tools > Grid topology. Then select Topology > Site > Node > SSM > Events.
/var/local/log/ntp.log
/var/lib/ntp/var/log/ntpstats/
/var/local/log/ntp.log contains the log file for NTP error messages.
/var/lib/ntp/var/log/ntpstats/ directory contains NTP timing statistics.
loopstats records loop filter statistics information.
peerstats records peer statistics information.
