Data types
Different data types are used to store information in audit messages.
| Type | Description |
UI32 |
Unsigned long integer (32 bits); it can store the numbers 0 to 4,294,967,295. |
UI64 |
Unsigned double long integer (64 bits); it can store the numbers 0 to 18,446,744,073,709,551,615. |
FC32 |
Four-character constant; a 32-bit unsigned integer value represented as four ASCII characters such as "ABCD." |
IPAD |
Used for IP addresses. |
CSTR |
A variable-length array of UTF-8 characters. Characters can be escaped with the following conventions:
