Manually trigger an AutoSupport message
PDF of this doc site
- Install and upgrade
- Configure and manage
Maintain
- Recover nodes and maintain your grid
Creating your file...
Your file is ready
To assist technical support in troubleshooting issues with your StorageGRID system, you can manually trigger an AutoSupport message to be sent.
Before you begin
You must be signed in to the Grid Manager using a supported web browser.
You must have the Root access or Other grid configuration permission.
Steps
Select SUPPORT > Tools > AutoSupport.
On the Settings tab, select Send User-Triggered AutoSupport.
StorageGRID attempts to send an AutoSupport message to technical support. If the attempt is successful, the Most Recent Result and Last Successful Time values on the Results tab are updated. If there is a problem, the Most Recent Result value updates to "Failed," and StorageGRID does not try to send the AutoSupport message again.
After sending an User-triggered AutoSupport message, refresh the AutoSupport page in your browser after 1 minute to access the most recent results.
