Automate appliance installation and configuration
Automating installation and configuration can be useful for deploying multiple StorageGRID instances or one large, complex StorageGRID instance.
Using NetApp StorageGRID tools, you can automate the installation and configuration of your StorageGRID appliances. After you install and configure the appliances, you can automate the configuration of the entire StorageGRID system.
You can automate the configuration of the following:
Grid Network, Admin Network, and Client Network IP addresses
BMC interface
Network links
Port bond mode
Network bond mode
Link speed
Automation options
To automate appliance installation and configuration, use one or more of the following options:
Generate a JSON file that contains configuration details. Work with your NetApp Professional Services consultant to use the NetApp ConfigBuilder tool to complete these steps:
Step Consult NetApp Professional Services Use ConfigBuilder 1
Get sales order number
2
Get workbook
3
Complete workbook
4
Upload workbook
5
Generate JSON file
6
Upload JSON file to appliance
7
Appliance ready for configuration. See Automate using Appliance Installer.
You can use the same JSON file to configure more than one appliance. Configuring your appliance using an uploaded JSON file is often more efficient than performing the configuration manually, especially if you have to configure many nodes. Performing the configuration manually requires using multiple pages in the StorageGRID Appliance Installer and applying the configuration file for each node one at a time.
If you are an advanced user, you can use the following StorageGRID Python scripts to install and configure your system:
configure-sga.py: Automate the installation and configuration of your appliances. See Automate appliance installation and configuration using configure-sga.py script. -
configure-storagegrid.py: Configure other components of the entire StorageGRID system (the "grid"). See Automate StorageGRID configuration.
You can use StorageGRID automation Python scripts directly, or you can use them as examples of how to use the StorageGRID Installation REST API in grid deployment and configuration tools you develop yourself. See the instructions for downloading and extracting the StorageGRID installation files. |
Automate appliance configuration using StorageGRID Appliance Installer
After you have generated a JSON file, you can automate the configuration of one or more appliances by using the StorageGRID Appliance Installer to upload the JSON file.
The appliance has been installed in a rack, connected to your networks, and powered on.
You have generated the JSON file with the guidance of your NetApp Professional Services consultant.
Your appliance contains the latest firmware compatible with StorageGRID 11.5 or higher.
You are connected to the StorageGRID Appliance Installer on the appliance you are configuring using a supported web browser.
In the StorageGRID Appliance Installer, select Advanced > Update Appliance Configuration. The Update Appliance Configuration page appears.
Browse for and select the JSON file with the configuration you want to upload.
The file is uploaded and validated. When the validation process is complete, the file name is shown next to a green check mark.
You might lose connection to the appliance if the configuration from the JSON file includes sections for link_config,networks, or both. If you aren't reconnected within 1 minute, re-enter the appliance URL using one of the other IP addresses assigned to the appliance.
The Node name drop down is populated with the top-level node names defined in the JSON file.
If the file is not valid, the file name is shown in red and an error message is displayed in a yellow banner. The invalid file is not applied to the appliance. ConfigBuilder verifies that you have a valid JSON file. -
Select a node from the list in the Node name drop down.
The Apply JSON configuration button becomes enabled.
Select Apply JSON configuration.
The configuration is applied to the selected node.
If you are an advanced user, you can use the configure-sga.py script to automate many of the installation and configuration tasks for StorageGRID appliance nodes, including installing and configuring a primary Admin Node. This script can be useful if you have a large number of appliances to configure.
You can also use the script to generate a JSON file that contains appliance configuration information. You can upload the JSON file to the StorageGRID Appliance Installer to configure all appliance nodes at the same time. You can also edit the JSON file, then upload it to apply a new configuration to one or more appliances.
This procedure is for advanced users with experience using command-line interfaces. Alternatively, you can use the StorageGRID Appliance Installer to automate the configuration. |
You have configured the IP address of the Admin Network for the appliance.
You have downloaded the
configure-sga.pyfile. The file is included in the installation archive, or you can access it by clicking Help > Appliance Installation Script in the StorageGRID Appliance Installer.
Log in to the Linux machine you are using to run the Python script.
For general help with the script syntax and to see a list of the available parameters, enter the following:
configure-sga.py --help
The
configure-sga.pyscript uses five subcommands:-
advancedfor advanced StorageGRID appliance interactions, including BMC configuration and creating a JSON file containing the current configuration of the appliance -
configurefor configuring the RAID mode, node name, and networking parameters -
installfor starting a StorageGRID installation -
monitorfor monitoring a StorageGRID installation -
rebootfor rebooting the applianceIf you enter a subcommand (advanced, configure, install, monitor, or reboot) argument followed by the
--helpoption you will get a different help text providing more detail on the options available within that subcommand:
configure-sga.py subcommand --helpIf you will back up the appliance configuration to a JSON file, ensure the node names follow these requirements:
Each node name is unique if you want to automatically configure all appliance nodes using a JSON file.
Must be a valid hostname containing at least 1 and no more than 32 characters.
Can use letters, numbers, and hyphens.
Can't start or end with a hyphen.
Can't contain only numbers.
To apply the configuration from the JSON file to the appliance, enter the following, where
SGA-INSTALL-IPis the Admin Network IP address for the appliance,json-file-nameis the name of the JSON file, andnode-name-inside-json-fileis the name of the node with the configuration being applied:
configure-sga.py advanced --restore-file json-file-name --restore-node node-name-inside-json-file SGA-INSTALL-IP -
To confirm the current configuration of the appliance node, enter the following where
SGA-INSTALL-IPis the Admin Network IP address for the appliance:
configure-sga.py configure SGA-INSTALL-IPThe results show current IP information for the appliance, including the IP address of the primary Admin Node and information about the Admin, Grid, and Client Networks.
Connecting to +https://10.224.2.30:8443+ (Checking version and connectivity.) 2021/02/25 16:25:11: Performing GET on /api/versions... Received 200 2021/02/25 16:25:11: Performing GET on /api/v2/system-info... Received 200 2021/02/25 16:25:11: Performing GET on /api/v2/admin-connection... Received 200 2021/02/25 16:25:11: Performing GET on /api/v2/link-config... Received 200 2021/02/25 16:25:11: Performing GET on /api/v2/networks... Received 200 2021/02/25 16:25:11: Performing GET on /api/v2/system-config... Received 200 StorageGRID Appliance Name: LAB-SGA-2-30 Node type: storage StorageGRID primary Admin Node IP: 172.16.1.170 State: unknown Message: Initializing... Version: Unknown Network Link Configuration Link Status Link State Speed (Gbps) ---- ----- ----- 1 Up 10 2 Up 10 3 Up 10 4 Up 10 5 Up 1 6 Down N/A Link Settings Port bond mode: FIXED Link speed: 10GBE Grid Network: ENABLED Bonding mode: active-backup VLAN: novlan MAC Addresses: 00:a0:98:59:8e:8a 00:a0:98:59:8e:82 Admin Network: ENABLED Bonding mode: no-bond MAC Addresses: 00:80:e5:29:70:f4 Client Network: ENABLED Bonding mode: active-backup VLAN: novlan MAC Addresses: 00:a0:98:59:8e:89 00:a0:98:59:8e:81 Grid Network CIDR: 172.16.2.30/21 (Static) MAC: 00:A0:98:59:8E:8A Gateway: 172.16.0.1 Subnets: 172.17.0.0/21 172.18.0.0/21 192.168.0.0/21 MTU: 1500 Admin Network CIDR: 10.224.2.30/21 (Static) MAC: 00:80:E5:29:70:F4 Gateway: 10.224.0.1 Subnets: 10.0.0.0/8 172.19.0.0/16 172.21.0.0/16 MTU: 1500 Client Network CIDR: 47.47.2.30/21 (Static) MAC: 00:A0:98:59:8E:89 Gateway: 47.47.0.1 MTU: 2000 ############################################################## ##### If you are satisfied with this configuration, ##### ##### execute the script with the "install" sub-command. ##### ############################################################## -
If you need to change any of the values in the current configuration, use the
configuresubcommand to update them. For example, if you want to change the IP address that the appliance uses for connection to the primary Admin Node to172.16.2.99, enter the following:configure-sga.py configure --admin-ip 172.16.2.99 _SGA-INSTALL-IP_
If you want to back up the appliance configuration to a JSON file, use the advanced and
backup-filesubcommands. For example, if you want to back up the configuration of an appliance with IP addressSGA-INSTALL-IPto a file namedappliance-SG1000.json, enter the following:
configure-sga.py advanced --backup-file appliance-SG1000.json SGA-INSTALL-IPThe JSON file containing the configuration information is written to the same directory you executed the script from.
Check that the top-level node name in the generated JSON file matches the appliance name. Don't make any changes to this file unless you are an experienced user and have a thorough understanding of StorageGRID APIs. -
When you are satisfied with the appliance configuration, use the
installandmonitorsubcommands to install the appliance:
configure-sga.py install --monitor SGA-INSTALL-IP -
If you want to reboot the appliance, enter the following:
configure-sga.py reboot SGA-INSTALL-IP
