The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Reset Archive Node connection to the cloud
PDF of this doc site
Install and upgrade
Configure and manage
Maintain
Recover nodes and maintain your grid
Creating your file...
Your file is ready
After you recover an Archive Node that targets the cloud through the S3 API, you need to modify configuration settings to reset connections. An Outbound Replication Status (ORSU) alarm is triggered if the Archive Node is unable to retrieve object data.
If your Archive Node connects to external storage through TSM middleware, then the node resets itself automatically and you don't need to reconfigure. |
Before you begin
You are signed in to the Grid Manager using a supported web browser.
Steps
Select SUPPORT > Tools > Grid topology.
Select Archive Node > ARC > Target.
Edit the Access Key field by entering an incorrect value and click Apply Changes.
Edit the Access Key field by entering the correct value and click Apply Changes.
