Configure ILM for FabricPool data
You can use this simple example policy as a starting point for your own ILM rules and policy.
This example assumes you are designing the ILM rules and an ILM policy for a StorageGRID system that has four Storage Nodes at a single data center in Denver, Colorado. The FabricPool data in this example uses a bucket named fabricpool-bucket.
The following ILM rules and policy are only examples. There are many ways to configure ILM rules. Before activating a new policy, simulate the proposed policy to confirm it will work as intended to protect content from loss. To learn more, see Manage objects with ILM. |
To avoid data loss, do not use an ILM rule that will expire or delete FabricPool cloud tier data. Set the retention period to forever to ensure that FabricPool objects aren't deleted by StorageGRID ILM. |
You have reviewed the best practices for using ILM with FabricPool data.
You are signed in to the Grid Manager using a supported web browser.
You have the ILM or Root access permission.
If you upgraded to StorageGRID 11.7 from a previous StorageGRID version, you have configured the storage pool you will use. In general, you should create a storage pool for each StorageGRID site.
This prerequisite does not apply to new StorageGRID 11.7 installations. When you install StorageGRID 11.7 on a new grid, storage pools are automatically created for each site.
Create an ILM rule that applies only to the data in
fabricpool-bucket. This example rule creates erasure-coded copies.Rule definition Example value Rule name
2 + 1 erasure coding for FabricPool data
Bucket name
fabricpool-bucketYou could also filter on the FabricPool tenant account.
Advanced filters
Object size greater than 0.2 MB.
Note: FabricPool only writes 4 MB objects, but you must add an Object size filter because this rule uses erasure coding.
Reference time
Ingest time
Time period and placements
From Day 0 store forever
Store objects by erasure coding using 2+1 EC scheme at Denver and retain those objects in StorageGRID forever.
To avoid data loss, do not use an ILM rule that will expire or delete FabricPool cloud tier data. Ingest behavior
Balanced
Create a default ILM rule that will create two replicated copies of any objects not matched by the first rule. Don't select a basic filter (tenant account or bucket name) or any advanced filters.
Two replicated copies
Bucket name
none
Advanced filters
none
Reference time
Ingest time
Store objects by replicating 2 copies at Denver.
Ingest behavior
Balanced
Create a proposed ILM policy and select the two rules. Because the replication rule does not use any filters, it can be the default (last) rule for the policy.
Ingest test objects into the grid.
Simulate the policy with the test objects to verify the behavior.
Activate the policy.
When this policy is activated, StorageGRID places object data as follows:
The data tiered from FabricPool in
fabricpool-bucketwill be erasure coded using the 2+1 erasure-coding scheme. Two data fragments and one parity fragment will be placed on three different Storage Nodes. -
All objects in all other buckets will be replicated. Two copies will be created and placed on two different Storage Nodes.
The copies will be maintained in StorageGRID forever. StorageGRID ILM won't delete these objects.
