View error codes (SG100 and SG1000)
If a hardware error occurs when the appliance is booting up, the BMC logs an error code. As required, you can view these error codes using the BMC interface, and then work with technical support to resolve the issue.
You know how to access the BMC dashboard.
From the BMC dashboard, select BIOS POST Code.
Review the information displayed for Current Code and the Previous Code. If any of the following error codes are shown, work with technical support to resolve the issue. Code Indicates 0x0E Microcode not found 0x0F Microcode not loaded 0x50 Memory initialization error. Invalid memory type or incompatible memory speed. 0x51 Memory initialization error. SPD reading has failed. 0x52 Memory initialization error. Invalid memory size or memory modules don't match. 0x53 Memory initialization error. No usable memory detected. 0x54 Unspecified memory initialization error 0x55 Memory not installed 0x56 Invalid CPU type or speed 0x57 CPU mismatch 0x58 CPU self-test failed, or possible CPU cache error 0x59 CPU micro-code is not found, or micro-code update failed 0x5A Internal CPU error 0x5B Reset PPI is not available 0x5C PEI phase BMC self-test failure 0xD0 CPU initialization error 0xD1 North bridge initialization error 0xD2 South bridge initialization error 0xD3 Some architectural protocols aren't available 0xD4 PCI resource allocation error. Out of resources. 0xD5 No space for legacy option ROM 0xD6 No console output devices are found 0xD7 No console input devices are found 0xD8 Invalid password 0xD9 Error loading boot option (LoadImage returned error) 0xDA Boot option failed (StartImage returned error) 0xDB Flash update failed 0xDC Reset protocol is not available 0xDD DXE phase BMC self-test failure 0xE8 MRC: ERR_NO_MEMORY 0xE9 MRC: ERR_LT_LOCK 0xEA MRC: ERR_DDR_INIT 0xEB MRC: ERR_MEM_TEST 0xEC MRC: ERR_VENDOR_SPECIFIC 0xED MRC: ERR_DIMM_COMPAT 0xEE MRC: ERR_MRC_COMPATIBILITY 0xEF MRC: ERR_MRC_STRUCT 0xF0 MRC: ERR_SET_VDD 0xF1 MRC: ERR_IOT_MEM_BUFFER 0xF2 MRC: ERR_RC_INTERNAL 0xF3 MRC: ERR_INVALID_REG_ACCESS 0xF4 MRC: ERR_SET_MC_FREQ 0xF5 MRC: ERR_READ_MC_FREQ 0x70 MRC: ERR_DIMM_CHANNEL 0x74 MRC: ERR_BIST_CHECK 0xF6 MRC: ERR_SMBUS 0xF7 MRC: ERR_PCU 0xF8 MRC: ERR_NGN 0xF9 MRC: ERR_INTERLEAVE_FAILURE
 PDFs
PDFs
