StorageGRID
Reboot controller while StorageGRID Appliance Installer is running
Contributors netapp-perveilerk netapp-pcelmer
You might need to reboot the compute controller while the StorageGRID Appliance Installer is running. For example, you might need to reboot the controller if the installation fails.
About this task
This procedure only applies when the compute controller is running the StorageGRID Appliance Installer. Once the installation is completed, this step no longer works because the StorageGRID Appliance Installer is no longer available.
Steps
  1. From the StorageGRID Appliance Installer, click Advanced > Reboot Controller, and then select one of these options:
    • Select Reboot into StorageGRID to reboot the controller with the node rejoining the grid. Select this option if you are done working in maintenance mode and are ready to return the node to normal operation.
    • Select Reboot into Maintenance Mode to reboot the controller with the node remaining in maintenance mode. (This option is available only when the controller is in maintenance mode.) Select this option if there are additional maintenance operations you need to perform on the node before rejoining the grid.
      Reboot controller in maintenance mode
      The controller is rebooted.
