Monitor node-level resources
PDF of this doc site
Install and maintain appliance hardware
Install and upgrade software
Perform system administration
Monitor and maintain StorageGRID
Recover and maintain
Grid node recovery procedures
Creating your file...
You should monitor individual grid nodes to check their resource utilization levels.
You must be signed in to the Grid Manager using a supported web browser.
If nodes are consistently overloaded, more nodes might be required for efficient operations.
To view information about hardware utilization of a grid node:
From the NODES page, select the node.
Select the Hardware tab to display graphs of CPU Utilization and Memory Usage.
To display a different time interval, select one of the controls above the chart or graph. You can display the information available for intervals of 1 hour, 1 day, 1 week, or 1 month. You can also set a custom interval, which allows you to specify date and time ranges.
If the node is hosted on a storage appliance or a services appliance, scroll down to view the tables of components. The status of all components should be “Nominal.” Investigate components that have any other status.
