View legacy alarms
Alarms (legacy system) are triggered when system attributes reach alarm threshold values. You can view the currently active alarms from the Current Alarms page.
Note While the legacy alarm system continues to be supported, the alert system offers significant benefits and is easier to use.
What you’ll need
Steps
  1. Select SUPPORT > Alarms (legacy) > Current alarms.
    Current Alarms Page
    The alarm icon indicates the severity of each alarm, as follows:
    Icon Color Alarm severity Meaning
    yellow square icon
    Yellow
    Notice
    The node is connected to the grid, but an unusual condition exists that does not affect normal operations.
    light orange diamond icon
    Light Orange
    Minor
    The node is connected to the grid, but an abnormal condition exists that could affect operation in the future. You should investigate to prevent escalation.
    dark orange diamond icon
    Dark Orange
    Major
    The node is connected to the grid, but an abnormal condition exists that currently affects operation. This requires prompt attention to prevent escalation.
    red x icon
    Red
    Critical
    The node is connected to the grid, but an abnormal condition exists that has stopped normal operations. You should address the issue immediately.
  2. To learn about the attribute that caused the alarm to be triggered, right click the attribute name in the table.
  3. To view additional details about an alarm, click the service name in the table.
    The Alarms tab for the selected service appears (SUPPORT > Tools > Grid topology > Grid Node > Service > Alarms).
    Alarms Acknowledging
  4. If you want to clear the count of current alarms, you can optionally do the following:
    • Acknowledge the alarm. An acknowledged alarm is no longer included in the count of legacy alarms unless it is triggered at the next severity level or it is resolved and occurs again.
    • Disable a particular Default alarm or Global Custom alarm for the entire system to prevent it from being triggered again.
Related information
Alarms reference (legacy system)
