Prepare site (SG100 and SG1000)
Before installing the appliance, you must make sure that the site and the cabinet or rack you plan to use meet the specifications for a StorageGRID appliance.
Steps
Confirm that the site meets the requirements for temperature, humidity, altitude range, airflow, heat dissipation, wiring, power, and grounding. See the NetApp Hardware Universe for more information.
Confirm that your location provides the correct voltage of AC power (in the range of 120 to 240 volts AC).
Obtain a 19-inch (48.3-cm) cabinet or rack to fit shelves of this size (without cables):
Height Width Depth Maximum weight 1.70 in.
(4.32 cm)
17.32 in.
(44.0 cm)
32.0 in.
(81.3 cm)
39 lb.
(17.7 kg)
Decide where you are going to install the appliance.
Related information
