Disable alert rules
You can change the enabled/disabled state for a default or custom alert rule.
What you'll need
You are signed in to the Grid Manager using a supported web browser.
You have the Manage Alerts or Root Access permission.
About this task
When an alert rule is disabled, its expressions are not evaluated and no alerts are triggered.
In general, disabling a default alert rule is not recommended. If an alert rule is disabled, you might not detect an underlying problem until it prevents a critical operation from completing. |
Steps
Select ALERTS > Rules.
The Alert Rules page appears.
Select the radio button for the alert rule you want to disable or enable.
Select Edit rule.
The Edit Rule dialog box appears.
Select or unselect the Enabled check box to determine if this alert rule is currently enabled.
If an alert rule is disabled, its expressions are not evaluated and no alerts are triggered.
If you disable the alert rule for a current alert, you must wait a few minutes for the alert to no longer display as an active alert. -
Select Save.
Disabled appears in the Status column.
