      View IP addresses
You can view the IP address for each grid node in your StorageGRID system. You can then use this IP address to log into the grid node at the command line and perform various maintenance procedures.
What you'll need
You are signed in to the Grid Manager using a supported web browser.
About this task
For information on changing IP addresses, see Recover and maintain.
Steps
Select NODES > grid node > Overview.
Select Show more to the right of the IP Addresses title.
The IP addresses for that grid node are listed in a table.
