Obtain additional equipment and tools (SG5700)
Before installing the StorageGRID appliance, confirm you have all of the additional equipment and tools that you need.
You need the following additional equipment to install and configure the hardware:
Screwdrivers
Phillips No. 2 screwdriver
Medium flat-blade screwdriver
ESD wrist strap
Optical cables and SFP transceivers
Optical cables for the 10/25-GbE ports you plan to use
Optional: SFP28 transceivers if you want to use 25-GbE link speed
Ethernet cables
Service laptop
SSH client, such as PuTTY
1-Gb (RJ-45) Ethernet port
Optional tools
Power drill with Phillips head bit
Flashlight
Mechanized lift for SG5760
