View a specific alert
You can view detailed information about an alert that is currently affecting your StorageGRID system or an alert that has been resolved. The details include recommended corrective actions, the time the alert was triggered, and the current value of the metrics related to this alert.
Optionally, you can silence a current alert or update the alert rule.
You are signed in to the Grid Manager using a supported web browser.
Do one of the following, based on whether you want to view a current or resolved alert:
Column header Description Current alert
From the Health panel on the Dashboard, click the Current alerts link. This link appears only if at least one alert is currently active. This link is hidden if there are no current alerts or if all current alerts have been silenced.
Select ALERTS > Current.
From the NODES page, select the Overview tab for a node that has an alert icon. Then, in the Alerts section, click the alert name.
Resolved alert
From the Health panel on the Dashboard, click the Recently resolved alerts link. (This link appears only if one or more alerts were triggered in the past week and are now resolved. This link is hidden if no alerts were triggered and resolved in the last week.)
Select ALERTS > Resolved.
As required, expand a group of alerts and then select the alert you want to view.
Select the alert, not the heading for a group of alerts.
A dialog box appears and provides details for the selected alert.
Review the alert details.
Information Description title
The name of the alert.
first paragraph
The description of the alert.
Recommended actions
The recommended actions for this alert.
Time triggered
The date and time the alert was triggered in your local time and in UTC.
Time resolved
For resolved alerts only, the date and time the alert was resolved in your local time and in UTC.
Status
The status of the alert: Active, Silenced, or Resolved.
Site/Node
The name of the site and node affected by the alert.
Severity
The severity of the alert.
Critical
: An abnormal condition exists that has stopped the normal operations of a StorageGRID node or service. You must address the underlying issue immediately. Service disruption and loss of data might result if the issue is not resolved. -
Major
: An abnormal condition exists that is either affecting current operations or approaching the threshold for a critical alert. You should investigate major alerts and address any underlying issues to ensure that the abnormal condition does not stop the normal operation of a StorageGRID node or service. -
Minor
: The system is operating normally, but an abnormal condition exists that could affect the system's ability to operate if it continues. You should monitor and resolve minor alerts that do not clear on their own to ensure they do not result in a more serious problem.
data values
The current value of the metric for this alert. For some alerts, additional values are shown to help you understand and investigate the alert. For example, the values shown for a Low metadata storage alert include the percent of disk space used, the total amount of disk space, and the amount of disk space used.
Optionally, click silence this alert to silence the alert rule that caused this alert to be triggered.
You must have the Manage Alerts or Root access permission to silence an alert rule.
Be careful when deciding to silence an alert rule. If an alert rule is silenced, you might not detect an underlying problem until it prevents a critical operation from completing. -
To view the current conditions for the alert rule:
From the alert details, click View conditions.
A pop-up appears, listing the Prometheus expression for each defined severity.
To close the pop-up, click anywhere outside of the pop-up.
Optionally, click Edit rule to edit the alert rule that caused this alert to be triggered:
You must have the Manage Alerts or Root access permission to edit an alert rule.
Be careful when deciding to edit an alert rule. If you change trigger values, you might not detect an underlying problem until it prevents a critical operation from completing. -
To close the alert details, click Close.
