Installation and deployment overview
You can install one or more StorageGRID services appliances when you first deploy StorageGRID, or you can add services appliance nodes later as part of an expansion.
Your StorageGRID system is using the required version of StorageGRID software.
| Appliance | Required StorageGRID version |
SG100 |
11.4 or later (latest hotfix recommended) |
SG1000 |
11.3 or later (latest hotfix recommended) |
Installation and deployment tasks
Preparing and adding a StorageGRID appliance to the grid includes four primary steps:
Preparing the installation site
Unpacking the boxes and checking the contents
Obtaining additional equipment and tools
Verifying network configuration
Optional: Configuring an external key management server (KMS) if you plan to encrypt all appliance data. See details about external key management in the instructions for administering StorageGRID.
Registering the hardware
Installing the appliance into a cabinet or rack
Cabling the appliance
Connecting the power cord and applying power
Viewing boot-up status codes
Accessing StorageGRID Appliance Installer and configuring the link and network IP settings required to connect to StorageGRID networks
Accessing the baseboard management controller (BMC) interface on the appliance.
Optional: Enabling node encryption if you plan to use an external KMS to encrypt appliance data.
Deploying an appliance Gateway or Admin Node
After the appliance hardware has been installed and configured, you can deploy the appliance as a Gateway Node and an Admin Node in a StorageGRID system. Both the SG100 and the SG1000 appliances can operate as Gateway Nodes and Admin Nodes (primary and non-primary) at the same time.
Task Instructions Deploying an appliance Gateway or Admin Node in a new StorageGRID system
Adding an appliance Gateway or Admin Node to an existing StorageGRID system
Deploying an appliance Gateway or Admin Node as part of a node recovery operation
