Modify DNS configuration for single grid node
Rather than configure the Domain Name System (DNS) globally for the entire deployment, you can run a script to configure DNS differently for each grid node.
In general, you should use the MAINTENANCE > Network > DNS servers option on the Grid Manager to configure DNS servers. Only use the following script if you need to use different DNS servers for different grid nodes.
Log in to the primary Admin Node:
Enter the following command:
ssh admin@primary_Admin_Node_IP -
Enter the password listed in the
Passwords.txtfile. -
Enter the following command to switch to root:
su - -
Passwords.txtfile.When you are logged in as root, the prompt changes from
$to#. -
Add the SSH private key to the SSH agent. Enter:
ssh-add -
Enter the SSH Access Password listed in the
Passwords.txtfile.
Log in to the node you want to update with a custom DNS configuration:
ssh node_IP_address -
Run the DNS setup script:
setup_resolv.rb.The script responds with the list of supported commands.
Tool to modify external name servers available commands: add search <domain> add a specified domain to search list e.g.> add search netapp.com remove search <domain> remove a specified domain from list e.g.> remove search netapp.com add nameserver <ip> add a specified IP address to the name server list e.g.> add nameserver 192.0.2.65 remove nameserver <ip> remove a specified IP address from list e.g.> remove nameserver 192.0.2.65 remove nameserver all remove all nameservers from list save write configuration to disk and quit abort quit without saving changes help display this help message Current list of name servers: 192.0.2.64 Name servers inherited from global DNS configuration: 192.0.2.126 192.0.2.127 Current list of search entries: netapp.com Enter command [`add search <domain>|remove search <domain>|add nameserver <ip>`] [`remove nameserver <ip>|remove nameserver all|save|abort|help`] -
Add the IPv4 address of a server that provides domain name service for your network:
add <nameserver IP_address> -
Repeat the
add nameservercommand to add name servers. -
Follow instructions as prompted for other commands.
Save your changes and exit the application:
save -
For each grid node, repeat the steps from logging into the node through closing the command shell.
When you no longer require passwordless access to other servers, remove the private key from the SSH agent. Enter:
ssh-add -D
