Remove a storage pool in StorageGRID
You can remove a storage pool that is not being used.
Before you begin
Steps
  1. Select ILM > Storage pools.
  2. Look at the ILM usage column in the table to determine whether you can remove the storage pool.
    You can't remove a storage pool if it is being used in an ILM rule or in an erasure-coding profile. As required, select storage pool name > ILM usage to determine where the storage pool is used.
  3. If the storage pool you want to remove is not being used, select the checkbox.
  4. Select Remove.
  5. Select OK.
