Identify the primary Admin Node
The primary Admin Node provides more functionality than non-primary Admin Nodes. For example, some maintenance procedures must be performed using the primary Admin Node.
For more information about Admin Nodes, see What is an Admin Node.
Before you begin
You are signed in to the Grid Manager using a supported web browser.
You have specific access permissions.
Steps
Select NODES.
Enter primary in the search box.
In the search results, identify the node with "Primary Admin Node" displayed in the Type column. One primary Admin Node should be listed.
