What is an Admin Node?
Admin Nodes provide management services such as system configuration, monitoring, and logging. Admin Nodes can also be used to load balance S3 client traffic. Each grid must have one primary Admin Node and might have any number of non-primary Admin Nodes for redundancy.
Differences between primary and non-primary Admin Nodes
When you sign in to the Grid Manager or the Tenant Manager, you are connecting to an Admin Node. You can connect to any Admin Node, and each Admin Node displays a similar view of the StorageGRID system. However, the primary Admin Node provides more functionality than non-primary Admin Nodes. For example, most maintenance procedures must be performed from the primary Admin Nodes.
The table summarizes the capabilities of primary and non-primary Admin Nodes.
Capabilities Primary Admin Node Non-primary Admin Node
Includes the AMS service
Yes
Yes
Includes the CMN service
Yes
No
Includes the NMS service
Yes
Yes
Includes the Prometheus service
Yes
Yes
Includes the SSM service
Yes
Yes
Includes the Load Balancer and High Availability services
Yes
Yes
Yes
Yes
Can be used for all network-related maintenance tasks, for example IP address change and updating NTP servers
Yes
No
Can perform EC rebalance after Storage Node expansion
Yes
No
Can be used for the volume restoration procedure
Yes
Yes
Can collect log files and system data from one or more nodes
Yes
No
Sends alert notifications, AutoSupport packages, and SNMP traps and informs
Yes. Acts as the preferred sender.
Yes. Acts as a standby sender.
Preferred sender Admin Node
If your StorageGRID deployment includes multiple Admin Nodes, the primary Admin Node is the preferred sender for alert notifications, AutoSupport packages, and SNMP traps and informs.
Under normal system operations, only the preferred sender sends notifications. However, all other Admin Nodes monitor the preferred sender. If a problem is detected, other Admin Nodes act as standby senders.
Multiple notifications might sent in these cases:
  • If Admin Nodes become "islanded" from each other, both the preferred sender and the standby senders will attempt to send notifications, and multiple copies of notifications might be received.
  • If standby sender detects problems with the preferred sender and starts sending notifications, the preferred sender might regain its ability to send notifications. If this occurs, duplicate notifications might be sent. The standby sender will stop sending notifications when it no longer detects errors on the preferred sender.
    Note When you test AutoSupport packages, all Admin Nodes send the test. When you test alert notifications, you must sign in to every Admin Node to verify connectivity.
Primary services for Admin Nodes
The following table shows the primary services for Admin Nodes; however, this table does not list all node services.
Service Key function
Audit Management System (AMS)
Tracks system activity and events.
Configuration Management Node (CMN)
Manages system-wide configuration.
High Availability
Manages high availability virtual IP addresses for groups of Admin Nodes and Gateway Nodes.
Note: This service is also found on Gateway Nodes.
Load Balancer
Provides load balancing of S3 traffic from clients to Storage Nodes.
Management Application Program Interface (mgmt-api)
Processes requests from the Grid Management API and the Tenant Management API.
Network Management System (NMS)
Provides functionality for the Grid Manager.
Prometheus
Collects and stores time-series metrics from the services on all nodes.
Server Status Monitor (SSM)
Monitors the operating system and underlying hardware.
