Perform additional StorageGRID node recovery steps
Contributors netapp-pcarriga netapp-maireadn netapp-lhalbert
Depending on the specific actions you took to get the StorageGRID nodes running on the replacement host, you might need to perform additional recovery steps for each node.
Node recovery is complete if you did not need to take any corrective actions while you replaced the Linux host or restored the failed grid node to the new host.
Corrective actions and next steps
During node replacement, you might have needed to take one of these corrective actions:
  • You had to use the --force flag to import the node.
  • For any <PURPOSE>, the value of the BLOCK_DEVICE_<PURPOSE> configuration file variable refers to a block device that does not contain the same data it did before the host failure.
  • You issued storagegrid node force-recovery node-name for the node.
  • You added a new block device.
If you took any of these corrective actions, you must perform additional recovery steps.
Type of recovery Next step
Primary Admin Node
Non-primary Admin Node
Gateway Node
Storage Node (software-based):
  • If you had to use the --force flag to import the node, or you issued storagegrid node force-recovery node-name
  • If you had to do a full node reinstall, or you needed to restore /var/local
  • If you added a new block device.
  • If, for any <PURPOSE>, the value of the BLOCK_DEVICE_<PURPOSE> configuration file variable refers to a block device that does not contain the same data it did before the host failure.
