Set up email notifications for StorageGRID alerts
If you want email notifications to be sent when alerts occur, you must provide information about your SMTP server. You must also enter email addresses for the recipients of alert notifications.
You are signed in to the Grid Manager using a supported web browser.
You have the Manage alerts or Root access permission.
You have configured an email server.
If your StorageGRID deployment includes multiple Admin Nodes, the primary Admin Node is the preferred sender for alert notifications, AutoSupport packages, and SNMP traps and informs. If the primary Admin Node becomes unavailable, notifications are temporarily sent by other Admin Nodes. See What is an Admin Node?.
Select Alerts > Alerts email.
The Alerts email page appears.
Select the Enable email for alerts checkbox to indicate that you want notification emails to be sent when alerts reach configured thresholds.
In the Receive email by severity section, select the radio button that indicates the types of alerts you want to be notified about.
In the Sender section, specify a valid email address to use as the From address for alert notifications.
For example:
storagegrid-alerts@example.com-
In the Recipients section, enter an email address for each email list or person who should receive an email when an alert occurs.
Select Add recipient to add recipients.
Select Save.
Information included in alert email notifications
After you configure the email server and enable email for alerts, email notifications are sent to the designated recipients when an alert is triggered, unless the alert rule is suppressed by a silence. Refer to Silence alert notifications.
Email notifications include the following information:
| Callout | Description |
1 |
The name of the alert, followed by the number of active instances of this alert. |
2 |
The description of the alert. |
3 |
Recommended actions for the alert. |
4 |
Details about each active instance of the alert, including the node and site affected, the alert severity, the UTC time when the alert rule was triggered, and the name of the affected job and service. |
5 |
The hostname of the Admin Node that sent the notification. |
How alerts are grouped
To prevent an excessive number of email notifications from being sent when alerts are triggered, StorageGRID attempts to group multiple alerts in the same notification.
Refer to the following table for examples of how StorageGRID groups multiple alerts in email notifications.
| Behavior | Example |
Each alert notification applies only to alerts that have the same name. If two alerts with different names are triggered at the same time, two email notifications are sent. |
For a specific alert on a specific node, if the thresholds are reached for more than one severity, a notification is sent only for the most severe alert. |
The first time an alert is triggered, StorageGRID waits 2 minutes before sending a notification. If other alerts with the same name are triggered during that time, StorageGRID groups all of the alerts in the initial notification. |
If an another alert with the same name is triggered, StorageGRID waits 10 minutes before sending a new notification. The new notification reports all active alerts (current alerts that have not been silenced), even if they were reported previously. |
If there are multiple current alerts with the same name and one of those alerts is resolved, a new notification is not sent if the alert reoccurs on the node for which the alert was resolved. |
StorageGRID continues to send email notifications once every 7 days until all instances of the alert are resolved or the alert rule is silenced. |
Troubleshoot alert email notifications
Follow these steps to investigate and resolve the issue if the Email notification failure alert is triggered and you are not receiving:
Test email server notifications
StorageGRID alert emails
Multi-admin verification (MAV) emails
You have the Root access permission. If you have the Manage alerts permission, you can view, but not edit, the email server configuration.
Verify your alert email settings.
Verify that you have specified valid email addresses for the recipients.
Select Configuration > Email server and verify that the Email (SMTP) server settings are correct.
Check your spam filter, and make sure that the email was not sent to a junk folder.
Ask your email administrator to confirm that emails from the sender address aren't being blocked.
Check the following items relating to email transfer:
Email server log monitoring: View the logs for the email server used by StorageGRID (Configuration > Email server). Search for relay errors, authentication errors, and other failures matching the time StorageGRID attempted to send an email.
Non-delivery reports (bounce-backs): If emails are not received and StorageGRID does not report a failure, the issue might be a bounce-back. Configuring the "from" address to use a valid email address will make these bounce-back reply emails visible to you.
Collect the log files for the Admin Node that is sending the emails. Review the /var/local/log/prometheus.log and /var/local/log/nms.log files for obvious issues you might be able to correct. If you are unable to resolve the issue contact technical support.
Technical support can use the information in the logs to help determine what went wrong. For example, the prometheus.log file might show an error when connecting to the server you specified.
Refer to Collect log files and system data.
