Copy the StorageGRID Grid CA certificate
Contributors netapp-pcarriga netapp-lhalbert
StorageGRID uses an internal certificate authority (CA) to secure internal traffic. This certificate does not change if you upload your own certificates.
Before you begin
About this task
If a custom server certificate has been configured, client applications should verify the server using the custom server certificate. They should not copy the CA certificate from the StorageGRID system.
Steps
  1. Select Configuration > Security > Certificates and then select the Grid CA tab.
  2. In the Certificate PEM section, download or copy the certificate.
    Download certificate file
    Download the certificate .pem file.
    1. Select Download certificate.
    2. Specify the certificate file name and download location. Save the file with the extension .pem.
      For example: storagegrid_certificate.pem
    Copy certificate PEM
    Copy the certificate text to paste elsewhere.
    1. Select Copy certificate PEM.
    2. Paste the copied certificate into a text editor.
    3. Save the text file with the extension .pem.
