      Resetting the Store Failure Count for S3 API connection
If your Archive Node connects to an archival storage system through the S3 API, you can reset the Store Failure Count, which can be used to clear the ARVF (Store Failures) alarm.
What you'll need
You must be signed in to the Grid Manager using a supported browser.
You must have specific access permissions.
Steps
Select Support > Tools > Grid Topology.
Select Archive Node > ARC > Store.
Select Configuration > Main.
Select Reset Store Failure Count.
Click Apply Changes. The Store Failures attribute resets to zero.
 PDFs
PDFs
