Turning the controller identify LED on and off
The blue identify LED on the front and back of the controller can be turned on to help locate the appliance in a data center.
What you'll need
You must have the BMC IP address of the controller you want to identify.
Steps
Access the controller BMC interface.
Select Server Identify.
Select ON and then select Perform Action.
Result
The blue identify LEDs light on the front (shown) and rear of the controller.
If a bezel is installed on the controller, it might be difficult to see the front identify LED. |
After you finish
To turn off the controller identify LED:
Press the identify LED switch on the controller front panel.
From the controller BMC interface, select Server Identify, select OFF and then select Perform Action.
The blue identify LEDs on the front and rear of the controller go off.
Related information
