Accessing the BMC interface
You can access the BMC interface on the services appliance using the DHCP or static IP address for the BMC management port.
The management client is using a supported web browser.
The BMC management port on the services appliance is connected to the management network you plan to use.
SG100 BMC management port
SG1000 BMC management port
Enter the URL for the BMC interface:
https://BMC_Port_IPFor
BMC_Port_IP, use the DHCP or static IP address for the BMC management port.The BMC sign-in page appears.
Enter the root username and password, using the password you set when you changed the default root password:
rootpassword
Click Sign me in
The BMC dashboard appears.
Optionally, create additional users by selecting Settings > User Management and clicking on any “disabled” user.
When users sign in for the first time, they might be prompted to change their password for increased security.
