Object metadata included in metadata notifications
The table lists all the fields that are included in the JSON document that is sent to the destination endpoint when search integration is enabled.
The document name includes the bucket name, object name, and version ID if present.
Type | Item name and description |
Bucket and object information |
System metadata |
User metadata |
Tags |
For tags and user metadata, StorageGRID passes dates and numbers to Elasticsearch as strings or as S3 event notifications. To configure Elasticsearch to interpret these strings as dates or numbers, follow the Elasticsearch instructions for dynamic field mapping and for mapping date formats. You must enable the dynamic field mappings on the index before you configure the search integration service. After a document is indexed, you cannot edit the document's field types in the index. |
