Changing your password
If you are a local user of the Grid Manager, you can change your own password.
What you'll need
You must be signed in to the Grid Manager using a supported browser.
About this task
If you sign in to StorageGRID as a federated user or if single sign-on (SSO) is enabled, you cannot change your password in Grid Manager. Instead, you must change your password in the external identity source, for example, Active Directory or OpenLDAP.
Steps
From the Grid Manager header, select your name > Change password.
Enter your current password.
Type a new password.
Your password must contain at least 8 and no more than 32 characters. Passwords are case-sensitive.
Re-enter the new password.
Click Save.
