Downloading and extracting the StorageGRID installation files
Before you can recover StorageGRID grid nodes, you must download the software and extract the files.
You must use the version of StorageGRID that is currently running on the grid.
Determine which version of the software is currently installed. From the Grid Manager, go to Help > About.
Go to the NetApp Downloads page for StorageGRID.
Select the version of StorageGRID that is currently running on the grid.
StorageGRID software versions have this format: 11.x.y.
Sign in with the username and password for your NetApp account.
Read the End User License Agreement, select the check box, and then select Accept & Continue.
In the Install StorageGRID column of the download page, select the
.tgzor.zipfile for your platform.The version shown in the installation archive file must match the version of the software that is currently installed.
Use the
.zipfile if you are running Windows.Platform Installation archive VMware
StorageGRID-Webscale-version-VMware-uniqueID.zipStorageGRID-Webscale-version-VMware-uniqueID.tgzRed Hat Enterprise Linux or CentOS
StorageGRID-Webscale-version-RPM-uniqueID.zipStorageGRID-Webscale-version-RPM-uniqueID.tgzUbuntu or Debian
or Appliances
StorageGRID-Webscale-version-DEB-uniqueID.zipStorageGRID-Webscale-version-DEB-uniqueID.tgzOpenStack or other hypervisor
NetApp-provided virtual machine disk files and scripts for OpenStack are no longer supported for recovery operations. If you need to recover a node running in an OpenStack deployment, download the files for your Linux operating system. Then, follow the procedure for replacing a Linux node.
Download and extract the archive file.
Follow the appropriate step for your platform to choose the files you need, based on your platform and which grid nodes you need to recover.
The paths listed in the step for each platform are relative to the top-level directory installed by the archive file.
If you are recovering a VMware system, select the appropriate files.
Path and file name Description ./vsphere/READMEA text file that describes all of the files contained in the StorageGRID download file.
./vsphere/NLF000000.txtA free license that does not provide any support entitlement for the product.
./vsphere/NetApp-SG-version-SHA.vmdkThe virtual machine disk file that is used as a template for creating grid node virtual machines.
./vsphere/vsphere-primary-admin.ovf./vsphere/vsphere-primary-admin.mfThe Open Virtualization Format template file (
.ovf) and manifest file (.mf) for deploying the primary Admin Node../vsphere/vsphere-non-primary-admin.ovf./vsphere/vsphere-non-primary-admin.mfThe template file (
.ovf) and manifest file (.mf) for deploying non-primary Admin Nodes./vsphere/vsphere-archive.ovf./vsphere/vsphere-archive.mfThe template file (
.ovf) and manifest file (.mf) for deploying Archive Nodes../vsphere/vsphere-gateway.ovf./vsphere/vsphere-gateway.mfThe template file (
.ovf) and manifest file (.mf) for deploying Gateway Nodes../vsphere/vsphere-storage.ovf./vsphere/vsphere-storage.mfThe template file (
.ovf) and manifest file (.mf) for deploying virtual machine-based Storage Nodes.Deployment scripting tool
./vsphere/deploy-vsphere-ovftool.shA Bash shell script used to automate the deployment of virtual grid nodes.
./vsphere/deploy-vsphere-ovftool-sample.iniA sample configuration file for use with the
deploy-vsphere-ovftool.shscript../vsphere/configure-storagegrid.pyA Python script used to automate the configuration of a StorageGRID system.
./vsphere/configure-sga.pyA Python script used to automate the configuration of StorageGRID appliances.
./vsphere/storagegrid-ssoauth.pyAn example Python script that you can use to sign in to the Grid Management API when single sign-on is enabled.
./vsphere/configure-storagegrid.sample.jsonA sample configuration file for use with the
configure-storagegrid.pyscript../vsphere/configure-storagegrid.blank.jsonA blank configuration file for use with the
configure-storagegrid.pyscript. -
If you are recovering a Red Hat Enterprise Linux or CentOS system, select the appropriate files.
Path and file name Description ./rpms/READMEA text file that describes all of the files contained in the StorageGRID download file.
./rpms/NLF000000.txtA free license that does not provide any support entitlement for the product.
./rpms/StorageGRID-Webscale-Images-version-SHA.rpmRPM package for installing the StorageGRID node images on your RHEL or CentOS hosts.
./rpms/StorageGRID-Webscale-Service-version-SHA.rpmRPM package for installing the StorageGRID host service on your RHEL or CentOS hosts.
./rpms/configure-storagegrid.pyA Python script used to automate the configuration of a StorageGRID system.
./rpms/configure-sga.pyA Python script used to automate the configuration of StorageGRID appliances.
./rpms/configure-storagegrid.sample.jsonA sample configuration file for use with the
configure-storagegrid.pyscript../rpms/storagegrid-ssoauth.pyAn example Python script that you can use to sign in to the Grid Management API when single sign-on is enabled.
./rpms/configure-storagegrid.blank.jsonA blank configuration file for use with the
configure-storagegrid.pyscript../rpms/extras/ansibleExample Ansible role and playbook for configuring RHEL or CentOS hosts for StorageGRID container deployment. You can customize the role or playbook as necessary.
If you are recovering an Ubuntu or Debian system, select the appropriate files.
Path and file name Description ./debs/READMEA text file that describes all of the files contained in the StorageGRID download file.
./debs/NLF000000.txtA non-production NetApp License File that you can use for testing and proof of concept deployments.
./debs/storagegrid-webscale-images-version-SHA.debDEB package for installing the StorageGRID node images on Ubuntu or Debian hosts.
./debs/storagegrid-webscale-images-version-SHA.deb.md5MD5 checksum for the file
/debs/storagegrid-webscale-images-version-SHA.deb./debs/storagegrid-webscale-service-version-SHA.debDEB package for installing the StorageGRID host service on Ubuntu or Debian hosts.
./debs/configure-storagegrid.pyA Python script used to automate the configuration of a StorageGRID system.
./debs/configure-sga.pyA Python script used to automate the configuration of StorageGRID appliances.
./debs/storagegrid-ssoauth.pyAn example Python script that you can use to sign in to the Grid Management API when single sign-on is enabled.
./debs/configure-storagegrid.sample.jsonA sample configuration file for use with the
configure-storagegrid.pyscript../debs/configure-storagegrid.blank.jsonA blank configuration file for use with the
configure-storagegrid.pyscript../debs/extras/ansibleExample Ansible role and playbook for configuring Ubuntu or Debian hosts for StorageGRID container deployment. You can customize the role or playbook as necessary.
If you are recovering a StorageGRID appliance-based system, select the appropriate files.
Path and file name Description ./debs/storagegrid-webscale-images-version-SHA.debDEB package for installing the StorageGRID node images on your appliances.
./debs/storagegrid-webscale-images-version-SHA.deb.md5Checksum of the DEB installation package used by the StorageGRID Appliance Installer to validate that the package is intact after upload.
Note: For appliance installation, these files are only required if you need to avoid network traffic. The appliance can download the required files from the primary Admin Node.
