Reinstalling the Fibre Channel HBA
PDF of this doc site
Install and upgrade software
Install and maintain hardware
SG5700 storage appliances
SG5600 storage appliances
Configure and manage
Administer StorageGRID
Use StorageGRID
Monitor and troubleshoot
Monitor a StorageGRID system
Creating your file...
The replacement Fibre Channel HBA is installed into the same location as the one that was removed.
You have the correct replacement Fibre Channel HBA.
You have removed the existing Fibre Channel HBA.
Wrap the strap end of the ESD wristband around your wrist, and secure the clip end to a metal ground to prevent static discharge.
Remove the replacement Fibre Channel HBA from its packaging.
With the blue adapter latch in the open position, align the Fibre Channel HBA with its connector on the riser assembly; then, carefully press the adapter into the connector until it is fully seated.
There are two adapters in the riser assembly: a Fibre Channel HBA and an Ethernet network adapter. The Fibre Channel HBA is indicated in the illustration.
Locate the alignment hole on the riser assembly (circled) that aligns with a guide pin on the system board to ensure correct riser assembly positioning.
Position the riser assembly in the chassis, making sure that it aligns with the connector and guide pin on the system board; then, insert the riser assembly.
Carefully press the riser assembly in place along its center line, next to the blue-marked holes, until it is fully seated.
Remove the protective caps from the Fibre Channel HBA ports where you will be reinstalling cables.
If you have no other maintenance procedures to perform in the controller, reinstall the controller cover.
