Controllers in the SG6000 appliances
Each model of the StorageGRIDSG6000 appliance includes an SG6000-CN compute controller in a 1U enclosure and duplex E-Series storage controllers in a 2U or 4U enclosure, depending on the model. Review the diagrams to learn more about each type of controller.
All appliances: SG6000-CN compute controller
Provides compute resources for the appliance.
Includes the StorageGRID Appliance Installer.
StorageGRID software is not preinstalled on the appliance. This software is retrieved from the Admin Node when you deploy the appliance. -
Can connect to all three StorageGRID networks, including the Grid Network, the Admin Network, and the Client Network.
Connects to the E-Series storage controllers and operates as the initiator.
This figure shows the connectors on the back of the SG6000-CN.
| Port | Type | Use | |
1 |
Interconnect ports 1-4 |
16-Gb/s Fibre Channel (FC), with integrated optics |
Connect the SG6000-CN controller to the E2800 controllers (two connections to each E2800). |
2 |
Network ports 1-4 |
10-GbE or 25-GbE, based on cable or SFP transceiver type, switch speed, and configured link speed |
Connect to the Grid Network and the Client Network for StorageGRID. |
3 |
BMC management port |
1-GbE (RJ-45) |
Connect to the SG6000-CN baseboard management controller. |
4 |
Diagnostic and support ports |
Reserved for technical support use. |
5 |
Admin Network port 1 |
1-GbE (RJ-45) |
Connect the SG6000-CN to the Admin Network for StorageGRID. |
6 |
Admin Network port 2 |
1-GbE (RJ-45) |
Options:
SG6060: E2800 storage controllers
Two controllers for failover support.
Manage the storage of data on the drives.
Function as standard E-Series controllers in a duplex configuration.
Include SANtricity OS Software (controller firmware).
Include SANtricity System Manager for monitoring storage hardware and for managing alerts, the AutoSupport feature, and the Drive Security feature.
Connect to the SG6000-CN controller and provide access to the storage.
This figure shows the connectors on the back of each of the E2800 controllers.
1 |
Interconnect ports 1 and 2 |
16-Gb/s FC optical SFPa |
Connect each of the E2800 controllers to the SG6000-CN controller. There are four connections to the SG6000-CN controller (two from each E2800). |
2 |
Management ports 1 and 2 |
1-Gb (RJ-45) Ethernet |
3 |
4 |
Drive expansion ports 1 and 2 |
12Gb/s SAS |
Connect the ports to the drive expansion ports on the IOMs in the expansion shelf. |
SGF6024: EF570 storage controllers
Connect to the SG6000-CN controller and provide access to the flash storage.
This figure shows the connectors on the back of each of the EF570 controllers.
1 |
Connect each of the EF570 controllers to the SG6000-CN controller. There are four connections to the SG6000-CN controller (two from each EF570). |
2 |
3 |
Drive expansion ports |
12Gb/s SAS |
Not used. The SGF6024 appliance does not support expansion drive shelves. |
4 |
SG6060: Input/output modules for optional expansion shelves
The expansion shelf contains two input/output modules (IOMs) that connect to the storage controllers or to other expansion shelves.
1 |
Drive expansion ports 1-4 |
12Gb/s SAS |
Connect each port to the storage controllers or additional expansion shelf (if any). |
