Viewing status indicators and buttons on the SG6000-CN controller
The SG6000-CN controller includes indicators that help you determine the status of the controller, including the following indicators and buttons.
| Display | Description | |
1 |
Power button |
2 |
Reset button |
No indicator Use this button to perform a hard reset of the controller. |
3 |
Identify button |
This button can be set to Blink, On (Solid), or Off. |
4 |
Alarm LED |
General boot-up codes
During boot-up or after a hard reset of the SG6000-CN controller, the following occurs:
The baseboard management controller (BMC) logs codes for the boot-up sequence, including any errors that occur.
The power button lights up.
If any errors occur during boot-up, the alarm LED lights up.
To view the boot-up and error codes, you must access the BMC interface.
