Adding a key management server (KMS)
PDF of this doc site
Install and upgrade software
Install and maintain hardware
SG5700 storage appliances
SG5600 storage appliances
Configure and manage
Administer StorageGRID
Use StorageGRID
Monitor and troubleshoot
Monitor a StorageGRID system
Creating your file...
You use the StorageGRID Key Management Server wizard to add each KMS or KMS cluster.
You must have reviewed the considerations and requirements for using a key management server.
You must have configured StorageGRID as a client in the KMS, and you must have the required information for each KMS or KMS cluster
You must have the Root Access permission.
You must be signed in to the Grid Manager using a supported browser.
If possible, configure any site-specific key management servers before configuring a default KMS that applies to all sites not managed by another KMS. If you create the default KMS first, all node-encrypted appliances in the grid will be encrypted by the default KMS. If you want to create a site-specific KMS later, you must first copy the current version of the encryption key from the default KMS to the new KMS.
