The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
How objects are stored (replication or erasure coding)
PDF of this doc site
Install and upgrade software
Install and maintain hardware
SG5700 storage appliances
SG5600 storage appliances
Configure and manage
Administer StorageGRID
Use StorageGRID
Monitor and troubleshoot
Monitor a StorageGRID system
Creating your file...
Your file is ready
StorageGRID can protect objects against loss either by storing replicated copies or by storing erasure-coded copies. You specify the type of copies to create in the placement instructions of ILM rules.
