Adding an NFS audit client to an audit share
NFS audit clients are granted access to an audit share based on their IP address. Grant access to the audit share to a new NFS audit client by adding its IP address to the audit share.
You must have the
Passwords.txtfile with the root/admin account password (available in the SAID package). -
You must have the
Configuration.txtfile (available in the SAID package). -
The audit client must be using NFS Version 3 (NFSv3).
Log in to the primary Admin Node:
Enter the following command:
ssh admin@primary_Admin_Node_IP -
Enter the password listed in the
Passwords.txtfile. -
Enter the following command to switch to root:
su - -
Passwords.txtfile.When you are logged in as root, the prompt changes from
$to#.
Start the NFS configuration utility:
config_nfs.rb----------------------------------------------------------------- | Shares | Clients | Config | ----------------------------------------------------------------- | add-audit-share | add-ip-to-share | validate-config | | enable-disable-share | remove-ip-from-share | refresh-config | | | | help | | | | exit | -----------------------------------------------------------------
Enter:
add-ip-to-shareA list of NFS audit shares enabled on the Admin Node is displayed. The audit share is listed as:
/var/local/audit/export -
Enter the number of the audit share:
audit_share_number -
When prompted, enter the audit client's IP address or IP address range for the audit share:
client_IP_addressThe audit client is added to the audit share.
When prompted, press Enter.
The NFS configuration utility is displayed.
Repeat the steps for each audit client that should be added to the audit share.
Optionally, verify your configuration:
validate-configThe services are checked and displayed.
Close the NFS configuration utility:
exit -
If the StorageGRID deployment is a single site, go to the next step.
Otherwise, if the StorageGRID deployment includes Admin Nodes at other sites, optionally enable these audit shares as required:
Remotely log in to a site's Admin Node:
ssh admin@grid_node_IP -
su - -
Passwords.txtfile.
Repeat these steps to configure the audit shares for each Admin Node.
Close the remote secure shell login to the remote Admin Node:
exit
Log out of the command shell:
exit
