Using the API if single sign-on is enabled
If single sign-on (SSO) has been enabled for your StorageGRID system, you cannot use the standard Authenticate API requests to sign in to and sign out of the Grid Management API or the Tenant Management API.
Signing in to the API if single sign-on is enabled
If single sign-on (SSO) has been enabled, you must issue a series of API requests to obtain an authentication token from AD FS that is valid for the Grid Management API or the Tenant Management API.
You know the SSO username and password for a federated user who belongs to a StorageGRID user group.
If you want to access the Tenant Management API, you know the tenant account ID.
To obtain an authentication token, you can use one of the following examples:
The
storagegrid-ssoauth.pyPython script, which is located in the StorageGRID installation files directory (./rpmsfor Red Hat Enterprise Linux or CentOS,./debsfor Ubuntu or Debian, and./vspherefor VMware). -
An example workflow of curl requests.
The curl workflow might time out if you perform it too slowly. You might see the error: A valid SubjectConfirmation was not found on this Response.
The example curl workflow does not protect the password from being seen by other users.
If you have a URL-encoding issue, you might see the error: Unsupported SAML version.
Select one of the following methods to obtain an authentication token:
Use the
storagegrid-ssoauth.pyPython script. Go to step 2. -
Use curl requests. Go to step 3.
If you want to use the
storagegrid-ssoauth.pyscript, pass the script to the Python interpreter and run the script.When prompted, enter values for the following arguments:
The SSO username
The domain where StorageGRID is installed
The address for StorageGRID
If you want to access the Tenant Management API, enter tenant account ID.
The StorageGRID authorization token is provided in the output. You can now use the token for other requests, similar to how you would use the API if SSO was not being used.
If you want to use curl requests, use the following procedure.
Declare the variables needed to sign in.
export SAMLUSER='my-sso-username' export SAMLPASSWORD='my-password' export SAMLDOMAIN='my-domain' export TENANTACCOUNTID=’12345’ export STORAGEGRID_ADDRESS='storagegrid.example.com' export AD_FS_ADDRESS='adfs.example.com'
To access the Grid Management API, use 0 as TENANTACCOUNTID. -
To receive a signed authentication URL, issue a POST request to
/api/v3/authorize-saml, and remove the additional JSON encoding from the response.This example shows a POST request for a signed authentication URL for
TENANTACCOUNTID. The results will be passed to python -m json.tool to remove the JSON encoding.curl -X POST "https://$STORAGEGRID_ADDRESS/api/v3/authorize-saml" \ -H "accept: application/json" -H "Content-Type: application/json" \ --data "{\"accountId\": \"$TENANTACCOUNTID\"}" | python -m json.toolThe response for this example includes a signed URL that is URL-encoded, but it does not include the additional JSON-encoding layer.
{ "apiVersion": "3.0", "data": "https://adfs.example.com/adfs/ls/?SAMLRequest=fZHLbsIwEEV%2FJTuv7...sSl%2BfQ33cvfwA%3D&RelayState=12345", "responseTime": "2018-11-06T16:30:23.355Z", "status": "success" } -
Save the
SAMLRequestfrom the response for use in subsequent commands.export SAMLREQUEST='fZHLbsIwEEV%2FJTuv7...sSl%2BfQ33cvfwA%3D'
Get a full URL that includes the client request ID from AD FS.
One option is to request the login form using the URL from the previous response.
curl "https://$AD_FS_ADDRESS/adfs/ls/?SAMLRequest=$SAMLREQUEST&RelayState=$TENANTACCOUNTID" | grep 'form method="post" id="loginForm"'
The response includes the client request ID:
<form method="post" id="loginForm" autocomplete="off" novalidate="novalidate" onKeyPress="if (event && event.keyCode == 13) Login.submitLoginRequest();" action="/adfs/ls/? SAMLRequest=fZHRToMwFIZfhb...UJikvo77sXPw%3D%3D&RelayState=12345&client-request-id=00000000-0000-0000-ee02-0080000000de" >
Save the client request ID from the response.
export SAMLREQUESTID='00000000-0000-0000-ee02-0080000000de'
Send your credentials to the form action from the previous response.
curl -X POST "https://$AD_FS_ADDRESS/adfs/ls/?SAMLRequest=$SAMLREQUEST&RelayState=$TENANTACCOUNTID&client-request-id=$SAMLREQUESTID" \ --data "UserName=$SAMLUSER@$SAMLDOMAIN&Password=$SAMLPASSWORD&AuthMethod=FormsAuthentication" --include
AD FS returns a 302 redirect, with additional information in the headers.
If multi-factor authentication (MFA) is enabled for your SSO system, the form post will also contain the second password or other credentials. HTTP/1.1 302 Found Content-Length: 0 Content-Type: text/html; charset=utf-8 Location: https://adfs.example.com/adfs/ls/?SAMLRequest=fZHRToMwFIZfhb...UJikvo77sXPw%3D%3D&RelayState=12345&client-request-id=00000000-0000-0000-ee02-0080000000de Set-Cookie: MSISAuth=AAEAADAvsHpXk6ApV...pmP0aEiNtJvWY=; path=/adfs; HttpOnly; Secure Date: Tue, 06 Nov 2018 16:55:05 GMT
Save the
MSISAuthcookie from the response.export MSISAuth='AAEAADAvsHpXk6ApV...pmP0aEiNtJvWY='
Send a GET request to the specified location with the cookies from the authentication POST.
curl "https://$AD_FS_ADDRESS/adfs/ls/?SAMLRequest=$SAMLREQUEST&RelayState=$TENANTACCOUNTID&client-request-id=$SAMLREQUESTID" \ --cookie "MSISAuth=$MSISAuth" --include
The response headers will contain AD FS session information for later logout usage, and the response body contains the SAMLResponse in a hidden form field.
HTTP/1.1 200 OK Cache-Control: no-cache,no-store Pragma: no-cache Content-Length: 5665 Content-Type: text/html; charset=utf-8 Expires: -1 Server: Microsoft-HTTPAPI/2.0 P3P: ADFS doesn't have P3P policy, please contact your site's admin for more details Set-Cookie: SamlSession=a3dpbnRlcnMtUHJpbWFyeS1BZG1pbi0xNzgmRmFsc2Umcng4NnJDZmFKVXFxVWx3bkl1MnFuUSUzZCUzZCYmJiYmXzE3MjAyZTA5LThmMDgtNDRkZC04Yzg5LTQ3NDUxYzA3ZjkzYw==; path=/adfs; HttpOnly; Secure Set-Cookie: MSISAuthenticated=MTEvNy8yMDE4IDQ6MzI6NTkgUE0=; path=/adfs; HttpOnly; Secure Set-Cookie: MSISLoopDetectionCookie=MjAxOC0xMS0wNzoxNjozMjo1OVpcMQ==; path=/adfs; HttpOnly; Secure Date: Wed, 07 Nov 2018 16:32:59 GMT <form method="POST" name="hiddenform" action="https://storagegrid.example.com:443/api/saml-response"> <input type="hidden" name="SAMLResponse" value="PHNhbWxwOlJlc3BvbnN...1scDpSZXNwb25zZT4=" /><input type="hidden" name="RelayState" value="12345" />
Save the
SAMLResponsefrom the hidden field:export SAMLResponse='PHNhbWxwOlJlc3BvbnN...1scDpSZXNwb25zZT4='
Using the saved
SAMLResponse, make a StorageGRID/api/saml-responserequest to generate a StorageGRID authentication token.For
RelayState, use the tenant account ID or use 0 if you want to sign in to the Grid Management API.curl -X POST "https://$STORAGEGRID_ADDRESS:443/api/saml-response" \ -H "accept: application/json" \ --data-urlencode "SAMLResponse=$SAMLResponse" \ --data-urlencode "RelayState=$TENANTACCOUNTID" \ | python -m json.tool
The response includes the authentication token.
{ "apiVersion": "3.0", "data": "56eb07bf-21f6-40b7-af0b-5c6cacfb25e7", "responseTime": "2018-11-07T21:32:53.486Z", "status": "success" } -
Save the authentication token in the response as
MYTOKEN.export MYTOKEN="56eb07bf-21f6-40b7-af0b-5c6cacfb25e7"
You can now use
MYTOKENfor other requests, similar to how you would use the API if SSO was not being used.
Signing out of the API if single sign-on is enabled
If single sign-on (SSO) has been enabled, you must issue a series of API requests to sign out of the Grid Management API or the Tenant Management API.
If required, you can sign out of the StorageGRID API simply by logging out from your organization's single logout page. Or, you can trigger single logout (SLO) from StorageGRID, which requires a valid StorageGRID bearer token.
To generate a signed logout request, pass
cookie "sso=true"to the SLO API:curl -k -X DELETE "https://$STORAGEGRID_ADDRESS/api/v3/authorize" \ -H "accept: application/json" \ -H "Authorization: Bearer $MYTOKEN" \ --cookie "sso=true" \ | python -m json.tool
A logout URL is returned:
{ "apiVersion": "3.0", "data": "https://adfs.example.com/adfs/ls/?SAMLRequest=fZDNboMwEIRfhZ...HcQ%3D%3D", "responseTime": "2018-11-20T22:20:30.839Z", "status": "success" } -
Save the logout URL.
export LOGOUT_REQUEST='https://adfs.example.com/adfs/ls/?SAMLRequest=fZDNboMwEIRfhZ...HcQ%3D%3D'
Send a request to the logout URL to trigger SLO and to redirect back to StorageGRID.
curl --include "$LOGOUT_REQUEST"
The 302 response is returned. The redirect location is not applicable to API-only logout.
HTTP/1.1 302 Found Location: https://$STORAGEGRID_ADDRESS:443/api/saml-logout?SAMLResponse=fVLLasMwEPwVo7ss%...%23rsa-sha256 Set-Cookie: MSISSignoutProtocol=U2FtbA==; expires=Tue, 20 Nov 2018 22:35:03 GMT; path=/adfs; HttpOnly; Secure
Delete the StorageGRID bearer token.
Deleting the StorageGRID bearer token works the same way as without SSO. If
cookie "sso=true"is not provided, the user is logged out of StorageGRID without affecting the SSO state.curl -X DELETE "https://$STORAGEGRID_ADDRESS/api/v3/authorize" \ -H "accept: application/json" \ -H "Authorization: Bearer $MYTOKEN" \ --include
A
204 No Contentresponse indicates the user is now signed out.HTTP/1.1 204 No Content
