Example 2: ILM rules and policy for EC object size filtering
You can use the following example rules and policy as starting points to define an ILM policy that filters by object size to meet recommended EC requirements.
Caution The following ILM rules and policy are only examples. There are many ways to configure ILM rules. Before activating a new policy, simulate the proposed policy to confirm it will work as intended to protect content from loss.
ILM rule 1 for example 2: Use EC for all objects larger than 200 KB
This example ILM rule erasure codes all objects larger than 200 KB (0.20 MB).
Rule definition Example value
Rule Name
EC only objects > 200 KB
Reference Time
Ingest Time
Advanced Filtering for Object Size
Object Size (MB) greater than 0.20
Content Placement
Create a 2+1 erasure-coded copy using three sites
The placement instructions specify that a 2+1 erasure-coded copy be created using all three sites.
ILM rule 2 for example 2: Two replicated copies
This example ILM rule creates two replicated copies and does not filter by object size. This rule is the second rule in the policy. Because ILM rule 1 for example 2 filters out all objects larger than 200 KB, ILM rule 2 for example 2 only applies to objects that are 200 KB or smaller.
Rule Name
Two Replicated Copies
Reference Time
Ingest Time
None
Content Placement
Create two replicated copies and save them at two data centers, DC1 and DC2
Example ILM Rule 2 for Example 2 - Two Replicated Copies
ILM policy for example 2: Use EC for objects larger than 200 KB
In this example policy, objects larger than 200 KB are erasure coded. Two replicated copies are made of all other objects.
This example ILM policy includes the following ILM rules:
  • Erasure code all objects larger than 200 KB.
  • If an object does not match the first ILM rule, use the default ILM rule to create two replicated copies of that object. Because objects larger than 200 KB have been filtered out by rule 1, rule 2 only applies to objects that are 200 KB or smaller.
