Considerations and recommendations for MAC address cloning
PDF of this doc site
Install and upgrade software
Install and maintain hardware
SG5700 storage appliances
SG5600 storage appliances
Configure and manage
Administer StorageGRID
Use StorageGRID
Monitor and troubleshoot
Monitor a StorageGRID system
Creating your file...
MAC address cloning causes the Docker container to use the MAC address of the host, and the host to use the MAC address of either an address you specify or a randomly generated one. You should use MAC address cloning to avoid the use of promiscuous mode network configurations.
Enabling MAC cloning
In certain environments, security can be enhanced through MAC address cloning because it enables you to use a dedicated virtual NIC for the Admin Network, Grid Network, and Client Network. Having the Docker container use the MAC address of the dedicated NIC on the host allows you to avoid using promiscuous mode network configurations.
MAC address cloning is intended to be used with virtual server installations and might not function properly with all physical appliance configurations. |
If a node fails to start due to a MAC cloning targeted interface being busy, you might need to set the link to "down" before starting node. Additionally, it is possible that the virtual environment might prevent MAC cloning on a network interface while the link is up. If a node fails to set the MAC address and start due to an interface being busy, setting the link to "down" before starting the node might fix the issue. |
MAC address cloning is disabled by default and must be set by node configuration keys. You should enable it when you install StorageGRID.
There is one key for each network:
ADMIN_NETWORK_TARGET_TYPE_INTERFACE_CLONE_MAC
GRID_NETWORK_TARGET_TYPE_INTERFACE_CLONE_MAC
CLIENT_NETWORK_TARGET_TYPE_INTERFACE_CLONE_MAC
Setting the key to "true" causes the Docker container to use the MAC address of the host's NIC. Additionally, the host will then use the MAC address of the specified container network. By default, the container address is a randomly generated address, but if you have set one using the _NETWORK_MAC
node configuration key, that address is used instead. The host and container will always have different MAC addresses.
Enabling MAC cloning on a virtual host without also enabling promiscuous mode on the hypervisor might cause Linux host networking using the host's interface to stop working. |
MAC cloning use cases
There are two use cases to consider with MAC cloning:
MAC cloning not enabled: When the
_CLONE_MAC
key in the node configuration file is not set, or set to "false," the host will use the host NIC MAC and the container will have a StorageGRID-generated MAC unless a MAC is specified in the_NETWORK_MAC
key. If an address is set in the_NETWORK_MAC
key, the container will have the address specified in the_NETWORK_MAC
key. This configuration of keys requires the use of promiscuous mode. -
MAC cloning enabled: When the
_CLONE_MAC
key in the node configuration file is set to "true," the container uses the host NIC MAC, and the host uses a StorageGRID-generated MAC unless a MAC is specified in the_NETWORK_MAC
key, the host uses the specified address instead of a generated one. In this configuration of keys, you should not use promiscuous mode.
If you do not want to use MAC address cloning and would rather allow all interfaces to receive and transmit data for MAC addresses other than the ones assigned by the hypervisor, ensure that the security properties at the virtual switch and port group levels are set to Accept for Promiscuous Mode, MAC Address Changes, and Forged Transmits. The values set on the virtual switch can be overridden by the values at the port group level, so ensure that settings are the same in both places. |
To enable MAC cloning, see the instructions for creating node configuration files.
MAC cloning example
Example of MAC cloning enabled with a host having MAC address of 11:22:33:44:55:66 for the interface ens256 and the following keys in the node configuration file:
ADMIN_NETWORK_TARGET = ens256
ADMIN_NETWORK_MAC = b2:9c:02:c2:27:10
ADMIN_NETWORK_TARGET_TYPE_INTERFACE_CLONE_MAC = true
Result: the host MAC for ens256 is b2:9c:02:c2:27:10 and the Admin Network MAC is 11:22:33:44:55:66
