Managing S3 buckets
If you are using an S3 tenant with the appropriate permissions, you can create, view, and delete S3 buckets, update consistency level settings, configure Cross-Origin Resource Sharing (CORS), enable and disable last access time update settings, and manage S3 platform services.
