Exporting text reports
Exported text reports open a new browser tab, which enables you to select and copy the data.
About this task
The copied data can then be saved into a new document (for example, a spreadsheet) and used to analyze the performance of the StorageGRID system.
Steps
Select Support > Tools > Grid Topology.
Create a text report.
Click *Export*
The Export Text Report window opens displaying the report.
Select and copy the contents of the Export Text Report window.
This data can now be pasted into a third-party document such as a spreadsheet.
