Disabling event-triggered AutoSupport messages
By default, the StorageGRID system is configured to send an AutoSupport message to NetApp Support when an important alert or other significant system event occurs.
What you'll need
You must be signed in to the Grid Manager using a supported browser.
You must have the Root Access or Other Grid Configuration permission.
About this task
You can disable event-triggered AutoSupport messages at any time.
Event-triggered AutoSupport messages are also suppressed when you suppress email notifications system wide. (Select Configuration > System Settings > Display Options. Then, select Notification Suppress All.) |
Steps
Select Support > Tools > AutoSupport.
The AutoSupport page appears with the Settings tab selected.
Clear the Enable Event-Triggered AutoSupport check box.
Select Save.
