Unable to connect to StorageGRID appliance over the network
If you cannot connect to the appliance, there might be a network issue, or the hardware installation might not have been completed successfully.
Issue
You cannot connect to the appliance.
Cause
This could occur if there is a network issue or the hardware installation did not complete successfully.
Corrective action
Ping the appliance:
ping E5600_controller_IP -
Access the StorageGRID Appliance Installer by opening a browser and entering the following:
https://Management_Port_IP:8443For Management_Port_IP, enter the IP address for management port 1 on the E5600SG controller (provisioned during the physical installation).
Click Configure Admin network, and check the IP.
If you receive a response from the ping, check that port 8443 is open in the firewalls.
Reboot the appliance.
Refresh the installation web page.
If this does not resolve the connection issue, contact technical support from the NetApp Support Site at mysupport.netapp.com.
