Linux: Exporting the node from the source host
Shut down the grid node and export it from the source Linux host.
Run the following command on the source Linux host.
Obtain the status of all nodes currently running on the source host.
sudo storagegrid node status all
Name Config-State Run-StateDC1-ADM1 Configured RunningDC1-ARC1 Configured RunningDC1-GW1 Configured RunningDC1-S1 Configured RunningDC1-S2 Configured RunningDC1-S3 Configured Running -
Identify the name of the node you want to migrate, and stop it if its Run-State is
Running.sudo storagegrid node stop DC1-S3
Stopping node DC1-S3Waiting up to 630 seconds for node shutdown -
Export the node from the source host.
sudo storagegrid node export DC1-S3
Finished exporting node DC1-S3 to /dev/mapper/sgws-dc1-s3-var-local.Use 'storagegrid node import /dev/mapper/sgws-dc1-s3-var-local' if youwant to import it again. -
Take note of the
import command suggested in the output of the `exportcommand.You will run this command on the target host in the next step.
