The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Forcing synchronization with the identity source
PDF of this doc site
Install and upgrade software
Install and maintain hardware
SG5700 storage appliances
SG5600 storage appliances
Configure and manage
Administer StorageGRID
Use StorageGRID
Monitor and troubleshoot
Monitor a StorageGRID system
Creating your file...
Your file is ready
The StorageGRID system periodically synchronizes federated groups and users from the identity source. You can force synchronization to start if you want to enable or restrict user permissions as quickly as possible.
What you'll need
You must be signed in to the Tenant Manager using a supported browser.
You must have specific access permissions.
The saved identity source must be enabled.
Steps
Select ACCESS MANAGEMENT > Identity federation.
The Identity federation page appears. The Sync server button is at the top right of the page.
If the saved identity source is not enabled, the Sync server button will not be active. -
Select Sync server.
A confirmation message is displayed indicating that synchronization started successfully.
Related information
