Obtaining additional equipment and tools (SG100 and SG1000)
Before installing the StorageGRID appliance, confirm you have all of the additional equipment and tools that you need.
You need the following additional equipment to install and configure the hardware:
  • Screwdrivers
    Two screwdrivers
    Phillips No. 2 screwdriver
    Medium flat-blade screwdriver
  • ESD wrist strap
    ESD wrist strap
  • Optical cables and transceivers
    Optical cable and QSFP+ transceiver
    • Cable
      • TwinAx/Copper (1 to 4)
        or
      • Fibre/Optical (1 to 4)
    • 1 to 4 of each of these transceivers/adapters based on link speed (mixed speeds are not supported)
      • SG100:
        Link speed (GbE) Required equipment
        10
        SFP+ transceiver
        25
        SFP28 transceiver
      • SG1000:
        10
        QSFP-to-SFP adapter (QSA) and SFP+ transceiver
        25
        QSFP-to-SFP adapter (QSA) and SFP28 transceiver
        40
        QSFP+ transceiver
        100
        QFSP28 transceiver
  • RJ-45 (Cat5/Cat5e/Cat6/Cat6a) Ethernet cables
    Ethernet cable
  • Service laptop
    Service laptop
    Supported web browser
    1-GbE (RJ-45) port
    Note Some ports might not support 10/100 Ethernet speeds.
  • Optional tools
    Power drill and flashlight
    Power drill with Phillips head bit
    Flashlight
