Disabling weekly AutoSupport messages
By default, the StorageGRID system is configured to send an AutoSupport message to NetApp Support once a week.
What you'll need
You must be signed in to the Grid Manager using a supported browser.
You must have the Root Access or Other Grid Configuration permission.
About this task
To determine when the weekly AutoSupport message is sent, see the Next Scheduled Time under Weekly AutoSupport on the AutoSupport > Results page.
You can disable the automatic sending of an AutoSupport message at any time.
Steps
Select Support > Tools > AutoSupport.
The AutoSupport page appears with the Settings tab selected.
Clear the Enable Weekly AutoSupport check box.
Select Save.
