Creating a platform services endpoint
You must create at least one endpoint of the correct type before you can enable a platform service.
You must be signed in to the Tenant Manager using a supported browser.
Platform services must be enabled for your tenant account by a StorageGRID administrator.
You must belong to a user group that has the Manage Endpoints permission.
The resource referenced by the platform services endpoint must have been created:
CloudMirror replication: S3 bucket
Event notification: SNS topic
Search notification: Elasticsearch index, if the destination cluster is not configured to automatically create indexes.
You must have the information about the destination resource:
Host and port for the Uniform Resource Identifier (URI)
If you plan to use a bucket hosted on a StorageGRID system as an endpoint for CloudMirror replication, contact the grid administrator to determine the values you need to enter. -
Unique Resource Name (URN)
Authentication credentials (if required):
Access Key: Access key ID and secret access key
Basic HTTP: Username and password
Security certificate (if using a custom CA certificate)
Select STORAGE (S3) > Platform services endpoints.
The Platform services endpoints page appears.
Select Create endpoint.
Enter a display name to briefly describe the endpoint and its purpose.
The type of platform service that the endpoint supports is shown beside the endpoint name when it is listed on the Endpoints page, so you do not need to include that information in the name.
In the URI field, specify the Unique Resource Identifier (URI) of the endpoint.
Use one of the following formats:
https://host:port http://host:port
If you do not specify a port, port 443 is used for HTTPS URIs and port 80 is used for HTTP URIs.
For example, the URI for a bucket hosted on StorageGRID might be:
https://s3.example.com:10443
In this example,
s3.example.comrepresents the DNS entry for the virtual IP (VIP) of the StorageGRID high availability (HA) group, and10443represents the port defined in the load balancer endpoint.Whenever possible, you should connect to a HA group of load-balancing nodes to avoid a single point of failure. Similarly, the URI for a bucket hosted on AWS might be:
https://s3-aws-region.amazonaws.com
If the endpoint is used for the CloudMirror replication service, do not include the bucket name in the URI. You include the bucket name in the URN field. -
Enter the Unique Resource Name (URN) for the endpoint.
You cannot change an endpoint's URN after the endpoint has been created. -
Select Continue.
Select a value for Authentication type, and then enter the required credentials.
The credentials that you supply must have write permissions for the destination resource.
Authentication type Description Credentials Anonymous
Provides anonymous access to the destination. Only works for endpoints that have security disabled.
No authentication.
Access Key
Uses AWS-style credentials to authenticate connections with the destination.
Access key ID
Secret access key
Basic HTTP
Uses a username and password to authenticate connections to the destination.
Username
Password
Select Continue.
Select a radio button for Verify server to choose how TLS connection to the endpoint is verified.
Type of certificate verification Description Use custom CA certificate
Use a custom security certificate. If you select this setting, copy and paste the custom security certificate in the CA Certificate text box.
Use operating system CA certificate
Use the default CA certificate installed on the operating system to secure connections.
Do not verify certificate
The certificate used for the TLS connection is not verified. This option is not secure.
Select Test and create endpoint.
A success message appears if the endpoint can be reached using the specified credentials. The connection to the endpoint is validated from one node at each site.
An error message appears if endpoint validation fails. If you need to modify the endpoint to correct the error, select Return to endpoint details and update the information. Then, select Test and create endpoint.
Endpoint creation fails if platform services are not enabled for your tenant account. Contact your StorageGRID administrator.
After you have configured an endpoint, you can use its URN to configure a platform service.
