The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Deleting a tenant account
PDF of this doc site
Install and upgrade software
Install and maintain hardware
SG5700 storage appliances
SG5600 storage appliances
Configure and manage
Administer StorageGRID
Use StorageGRID
Monitor and troubleshoot
Monitor a StorageGRID system
Creating your file...
Your file is ready
You can delete a tenant account if you want to permanently remove the tenant's access to the system.
What you'll need
You must be signed in to the Grid Manager using a supported browser.
You must have specific access permissions.
You must have removed all buckets (S3), containers (Swift), and objects associated with the tenant account.
Steps
Select Tenants.
Select the tenant account you want to delete.
If your system includes more than 20 items, you can specify how many rows are shown on each page at one time. Use the search box to search for a tenant account by display name or tenant ID.
From the Actions drop-down, select Remove.
Select OK.
Related information
