Navigating to the Grid Manager
You use the Grid Manager to define all of the information required to configure your StorageGRID system.
What you'll need
The primary Admin Node must be deployed and have completed the initial startup sequence.
Steps
Open your web browser and navigate to one of the following addresses:
https://primary_admin_node_ipclient_network_ipAlternatively, you can access the Grid Manager on port 8443:
https://primary_admin_node_ip:8443You can use the IP address for the primary Admin Node IP on the Grid Network or on the Admin Network, as appropriate for your network configuration. -
Click Install a StorageGRID system.
The page used to configure a StorageGRID grid appears.
