SREM: Object Store Remove
This message is issued when content is removed from persistent storage and is no longer accessible through regular APIs.
| Code | Field | Description |
CBID |
Content Block Identifier |
The unique identifier of the content block deleted from permanent storage. |
RSLT |
Result Code |
Indicates the result of the content removal operations. The only defined value is: SUCS: Content removed from persistent storage |
This audit message means a given content block has been deleted from a node and can no longer be requested directly. The message can be used to track the flow of deleted content within the system.
